Smile 901 transmission
Hi all, would like a little help. Hope this doesnt come across as too obtuse, however, the small lever that is next to the shifter on the floor in the car...what is that? and what is it for? Thanks!!
Old 04-12-2009, 10:39 PM
Max Sluiter
Flieger's Avatar
The one to the left of the hand brake is the hand throttle. It pulls on the throttle pedal cable so that you can "choke" the car for start-up, especially in cold weather.
The one on the right of the hand brake is the heater control lever.
Old 04-12-2009, 10:44 PM
ok...so thats the little lever right next to the floor shifter? ...but its not near the handbrake? a little confused... it seems to be more in front of the shifter on the left pointing kinda left
cheers
Old 04-12-2009, 10:55 PM
heat.
206 637 4071
Old 04-13-2009, 05:04 AM
<insert witty title here>
Christien's Avatar
Here's a pic I just found of the heater and hand throttle levers, both labeled. From your description, I don't think you're talking about either of these. Maybe post a pic so we can see exactly what you're talking about, if it's not this:
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 04-13-2009, 06:19 AM
G2B humble as well, eh? Do you have a very early 911, 912? If so, the lever is heat, kind of forward left of the shift lever. later cars had it right of hand brake. Hope this helps.
Have a great day.
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 04-13-2009, 06:40 AM
