whackit's Avatar
Replace early door handle stud?
Hi Folks.
I have an early door handle that the inner stud broke off of. Does anyone know a procedure for replacing these. I know this much:
1. The studs look like they were originally stud welded in place.
2. The metal is some sort of VERY soft pot metal with a low melting point. welding and or brazing are out of the question (tried it on a crappy one).
3. JB weld is too weak (tried it)
4. I might try to drill and tap + helicoil but there is very little room for a hole, roughly 6mm of depth.
5. my handles are freshly plated (of course) so I would rather not screw that up.
Ideas?
1971 911E 2.7RS interpretation -- Signal Orange baby!
Old 04-11-2009, 06:12 PM
drill and tap. one shot, so be go slow.
206 637 4071
Old 04-11-2009, 06:29 PM
whackit's Avatar
it's such a shallow hole... did you just do a straight thread or a helicoil?
Old 04-11-2009, 06:32 PM
just drill and tap, no insert. helicoils suck, FWIW. tap as deep as possible, then grind the tip of the tap flat and get a couple more threads in. you could loctite it, but shouldn't be necessary.
206 637 4071
Old 04-11-2009, 06:44 PM
Here's a link to some photos I posted regarding my experience with this drill and tap situation.
http://www.912bbs.org/index.php?a=topic&t=28751&hl=door+lock+stud
John Thompson
Eugene, Oregon
Old 04-11-2009, 09:47 PM
