911Etarga's Avatar
Timing for a 2.2E??
I have been trying to find a chart or some info on the correct timing angle for my 2.2E, but I am having troubles. I have 101, but it says to look at the spec book, which I don't have.
Does anyone know what I should set the timing at?? It's my first time.
Thanks!
'71 911E Targa
Old 04-13-2009, 02:15 PM
Hotrod911T's Avatar
If you are referring to ignition timing, the factory spec for a 1970/71 911E and 911S is 30 degrees BTDC at 6000 rpm.
Rod
Old 04-13-2009, 02:24 PM
911Etarga's Avatar
Thanks Rod,
Is 10 degrees at 800rpm to much?? The sticker on my engine says 5 deg.
'71 911E Targa
Old 04-13-2009, 03:18 PM
You need a strobe light and time it for max advance, previous post. Only safe way for your motor.
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 04-13-2009, 05:05 PM
(the shotguns)
berettafan's Avatar
w/ no vacuum advance the idle timing will fall where it will. 800 is, i think, a touch low for idle.
variations can be caused by a sticky advance mechanism. imo if there is any doubt you should have the dizzy rebuilt (or do yourself if you can) to include cleaning up the advance mech. while you're at it you can have the rebuilder check the advance curve so you KNOW what you've got.
i tend to be nervous about my timing and i throw a light on my car several times a year to see where i'm at. learned just how quickly points wear by doing this.
Old 04-13-2009, 06:20 PM
Here's a like to some help.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/449688-correct-2-2-bosch-distributor.html#post4398155
The graph shows DISTRIBUTOR speed and anvance so you need to double the numbers to get ENGINE speed and advance.
On the graph, 3000 rpm is 6000 engine speed, 15 degrees is 30 on the engine.
Also, the 2 lines show the range, so anything in between is good for either E or S
Hope this helps,
Robo
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 04-14-2009, 10:10 AM
