plymouthcolt's Avatar
Sunroof open at 120 mph?
The manual says not to operate the sunroof above 61 mph. I assumed operate meant don't have it open above 61 mph.
Then I thought as long as it's open and I don't try to close (operate) it, can I exceed 61 mph with it open?
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 04-25-2009, 06:41 PM
Red Clubbie's Avatar
I'd assume operate means "movement"...if it's open, don't close it and if it's closed, don't open it at those speeds.
Cheers,
Geoff.
1984 911 Carrera.......
Old 04-25-2009, 06:49 PM
Almost Banned Once
sc_rufctr's Avatar
If I was planning on driving at 120 miles per hour I would close my sunroof...
For safe operation at those speeds your P car needs to be the best aerodynamically it can be...
Why risk it? There is no benefit in air circulation or anything else from the sunroof at that speed.
- Peter
Old 04-25-2009, 06:55 PM
the the is offline
I think as long as you have your seatbelt on so you don't get sucked out through the roof, you'll be ok.
Old 04-25-2009, 06:57 PM
ZAMIRZ's Avatar
I'm always driving and operating it at 85 to 90 on the freeway...been ok for 24 years now.
Amir
'83 911SC
Old 04-25-2009, 06:58 PM
Formerly reformed
Having the sunroof open in my e36 at ~125 recently caused some heinous thumping in the cabin. It's probably for the same reasons.
1968 911P (Paperweight)
Old 04-25-2009, 08:01 PM
Ken911's Avatar
you think 120 is bad with it open try 150 with the windows open. even with a helmet on it was really loud
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 04-25-2009, 09:05 PM
The roof liner starts to violently rock around at over 100 mph w/roof open.
btdt roof open at 120 mph
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-25-2009, 09:07 PM
Keepin' it Simple...
R_Builder's Avatar
I have done several track days in my SC with the windows down and the sunroof open to clear my helmet (what a pain) without issue. Nothing like flying down the back straight at Willow doing 115 mph with the sunroof open! It might be loud, but I have other things on my mind... like turn 9.
-Doug
1968 911R Clone; 11/07-?? (forever the project car )
1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers)
1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home)
1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany)
Old 04-25-2009, 10:17 PM
Turboo934's Avatar
Do it for any length of time temps of motor will run hot. Disrupts the air flow to the motor.
Old 04-26-2009, 12:03 AM
maybe most so
I ran for 30 mi heading north of Austin Nev on sr305 between 100-120 and no noticeable difference. Just the initial 10F oil temp jump from 70 average to another 10F rise at 90 and another 10F rise at 110-120. It was a fairly linear curve of 10F for every 20 mph increase. I started at 180F at a steady 70mph. Ambient temps was about 70-75F. I only have a fender oil cooler.
CHTs went from 275F av at 70, to 290-300 at 100, to 320ish at 120. It would have kept climbing but I had enough. The more hp the higher the CHTs. My engine is probably 200hp. Those are good CHTs and my probes & meter are accurate.
EGTs actually went down at higher speeds. This cracked me up big time. I was so concerned about having the right carb E-tubes for these runs. For the record they dropped about 25F. That's noticeable.
.....only my experience
ps: doing what I do and accelerating around a track to speed is another story
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-26-2009, 01:57 AM
