Any suggestions for Fuel Line replacement - CIS FD to injectors
I replaced my intake manifold gaskets, fuel injection seals, and injector sleeves this week (trying to eliminate vaccum leaks). In the process, I broke the fuel line from the WUR to the fuel distributor.
I was able to cut the end off the line and reconnect to the barbed fitting on the WUR but I want to replace all of those hard plastic lines with new lines. When I check Pelican, they only cary the lines for cylinders 1,2, & 3. So, I started searching the internet and there is a huge price variance ranging from $85 each to $25 each. I'm wondering why this is and what have others done. Since were dealing with fuel, I don't want to take chances but I would like to hear if there are alternative options (ie., fabricating metal, etc..). Thanks.......Vern |
A bought them all new a few years ago for what seemed like reasonable money, don't remember where. They are nominally hard plastic, so don't let that scare you too much. Having said that, they are quite old at this point! Some recommend buying nylon tubing and making your own, search around a bit her or on other boards. Even at high $, better than a fuel/air bomb in your tail!
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
Do a search the is a fellow here on the site that sells them and or the tool and lines to do your owm.
Lorne M.
83 SC |
Ed 1973.5 T |
Vern,
You can always go insane and make your own !!!! ![]() ![]() Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Thanks for all the great info. I sent an e-mail to unobtainium and will buy theri kit.
I think I will go for the "Cole Look" and get the braided steel. Vern |
Scroll down to the bottom of post 377 here to see some really nice Greg Brown lines.
Found 30 Years Later Last time I searched, they seemed a bit pricey. Shawn
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...." -- William Faulkner |
grateful user
cheapest and fastet way, go to car quest, they have high press. black plastic air brake line for big trucks, rated at like 600lb, metric sizes, (i think 4mm id worked) works great, just cut to fit.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
There was this a while back...
excellent way to test injectors on 78 911 Post #6 says from a junkyard jetta. Not specific though.
Taking it apart is easy
Any idea of how well those hoses resist ethanol? I'd like to take that into account.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Vw Dealer, I have been told has the fuel line. Check manufacturer specs on air brake line, when I did mine I was going to use it but the specs said NOT approved for fuel delivery. HTH
The lines are nylon 6/6T. I believe MSC carries these lines in bulk in metric sizes.
grateful user
My "air brake line" has been holding up well on mine and several others now going on 7 yrs. But good point, make sure you buy good hose that is "oil impervious" ? i think thats what it said on the bulk box I bought. (at Car Quest)
