coilover setup question
i am thinking about going over to coil overs, i know how to weld so bracing the front and rear towers is no issue. i was wondering what else has to be done and if anyone has picture of there set ups or braces.
Jon
Old 04-16-2009, 12:22 PM
RichF's Avatar
I was wondering the same thing the other day. Someone share!!!!
"Work harder........... Millions on welfare depend on you"
" If you aint cheaten you aint tryin"
Old 04-16-2009, 12:36 PM
911ctS's Avatar
Send a message via Yahoo to 911ctS
For the front a simple triangulated strut brace is sufficient. Or you can weld a piece of tubing across to connect the two shock towers. If you get crazy you can install an X brace to connect more of the front chassis.
For the rear I would suggest connecting the two shock towers with a piece of tubing and also weld the tubing at the midpoint where it comes very close to the rear cross member. In addition to that, I would add some triangular gussets to the outer sides of the shock towers or tubes that protrude into the engine compartment.
Is it all necessary? I don't 100% know for sure, really depends upon spring rates. If you can weld nicely and want to tackle the job then it certainly will not hurt.
Fernando's web write up is a nice reference to check out: http://www.readynet.com/myproject/index.html
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 04-16-2009, 02:25 PM
barney911rs's Avatar
Clint is the man for the coil over stuff. He helped me get all my parts and stuff. There is an old thread with lots of pictures about the rear bracing. I'll try and find is and put a link in here.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 04-16-2009, 06:02 PM
Here's a good thread to read
RSR Rear Shock Reinforcements
Maxx
86 Ruf'd and rebuilt (sold)
Old 04-16-2009, 07:04 PM
Platinum Member
dad911's Avatar
I had coil-overs in a dedicated track car about 10 years ago. Frankly, unless it is a stripped, dedicated race car with a full cage, I wouldn't bother with the expense. A properly set up torsion bar car will handle as well.
Also, wheel fitment in the front may be an issue. Turbo or larger flares?
Old 04-16-2009, 07:46 PM
Thanks Maxx, that was the thread I was referring to
John Snodgrass
Old 04-16-2009, 08:07 PM
JMatta's Avatar
I've run rear coilovers with front torsion bars on my '73 for the last eight years without issue. There was minimal bracing done in the rear towers and all is strong. This is mostly a DE car, though built for vintage racing, it does not see the stress of full season track car. I chose to go this route and avoid the rear torsion bar hassle...my car builder had no problem sourcing parts, mostly from TRG.
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 04-16-2009, 08:10 PM
thanks everyone these links are perfect!
Old 04-17-2009, 10:13 AM
