Side window tint removal
Hello- I would like to remove the tint film on the side windows. How is this best done-solvent? heat gun? Thanks
Banned
Mine just peeled off with a razor blade.
And if the above doesn't work. Ammonia diluted around 75%, with 25% water, warm garage space...or in the sun on a summer day is best. Cover door panel and other areas with plastic, ammonia will stain just like clorox, spray on and keep damp until it comes off easily with a clean sharp razor with only forward motions (not back and forth) as it will minimize the chances of scratching your glass.
To add to the above ammonia recipe:
Spray the window with the ammonia solution, then cover with a pre-cut piece of black plastic (garbage bag). This will keep the solution from evaporating too quickly. The garbage bag/solution goes on the INSIDE of the window. Face that window toward the sun (the hotter day, the better) and wait about 30 ~ 60 mins. The tinting will peel off easier than a drunk college girls panties... |
Living up to the name
Orrrr......
Use a small steamer (like from Walgreen's for $25 or so) to heat it up - the film on each of my side windows peeled off in a single sheet once heated sufficiently with the steamer. Did the back window as well - easy peasy!
2008 911 (997) C4 Carrara White The sweet old 1988 911 GP White has gone to a new owner "Keep your head in the clouds and your right foot mashed to the floorboard!" ~Village Idiot |
Whoa whoa whoa, before you start huffing that ammonia, just hang on a second.
I've used both methods, the ammonia and the clothing steamer. Please, do yourself a humongous favor, use the clothing steamer. The ammonia is effective, but messy, and the vapors are noxious. The clothing steamer is incredibly simple and clean. I did my side windows in October in all of 5 minutes TOTAL.
88' Carrera, Black/Black/Black, "Murdered Out" OEM. 06' BMW 'M' Roadster (Wife's car and WAY faster than mine) |
+1 on the steamer.
I borrowed a small "travel steamer"...so small it only had less than a cup of water...but good for about 20 minutes. But that was all it took for one door and yes, they peeled off in whole sheets. I started at a top corner and worked my way down. Taped a plastic sheet at the bottom of the window to keep stray moisture off the door panel. One sheet left a little "adhesive" behind, but the steamer softened it up to the point when I could wipe it off with a towel.
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
Checked out
steamer works ok.
I prefer the ammonia b/c it is faster and more thorough. |
There is no need to mix up a specific batch of diluted ammonia. Just use Windex or any window cleaner that contains ammonia, and do the above mentioned procedure with the precut trash bag and sunlight and/or heat. It will work like a charm.
Gone 92 C2 82 Euro SC race car 993 C4S 3.8 84 Euro Carrera |
Ruby911
+1 on the steamer. did it, it worked great.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
+ lurking - contributing
I am glad I never threw out the garmet steamer my Mom gave me before I went to college...never had any need for it until now!
87 930 96 BMW M3 Coupe 89 951 08 Astra H Peugeot moped |
