Fly wheel thickness
What is the minimum thickness for a 1980 3.0 flywheel.
I need to have mine turned and balanced and can not find the spec. Thanks.
Silver 1980SC Euro coupe |
Schleprock
Here's some info. from previous posts. The spec. for the 84-86 Carrera is the same as the SC, which is 8.5 mm. Ignore the G50 references in the topics below
When to resurface a flywheel?? G50 Transmission Question (odd noise or???) . . . .
Kevin L '86 Carrera "Larry" |
Just what I needed!
Thanks again.
