Rennshift long vs short
Anyone have any experience w/ the long and short versions of the Rennshift gated shifter?
Old 09-02-2008, 10:53 AM
Cornpanzer's Avatar
I love my standard Rennshift , but I would love to hear if anyone has tried the long handle. The standard is just slightly too far forward for my comfort, but I dont want the throws to get too long either. Anyone, anyone???
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 04-18-2009, 06:13 PM
scottb's Avatar
I have the same issue and concerns. Subscribing.
1984 Targa
Old 04-18-2009, 06:53 PM
I bought the long one. There were only 2 choices, short and long. I have short arms so the short might have been the wrong choice for me. As it is, I am happy w/ the long one.
But I still would like to know if anyone has any direct experience between the long and short.
Old 04-18-2009, 09:19 PM
Hotrod911T's Avatar
When I bought our 901 Rennshift shifter a few years ago, it only came with the short shift handle. In order to center the handle for the reverse lockout, the forward throws were a little too far forward for my wife who co-drives the car with me. I installed the longer handle, which is angled a little more to the rear, and like the shift throws much better now.
Rod
Old 04-18-2009, 09:33 PM
A bit off topic but relevant.. When I installed a Factory short shifter in my 1973, I still had the same problem I had with the standard factory shifter.
My drivers seat is as far back as possible which meant that I had to lean forward to shift gears.
I cut approximately 3 inches off the standard shifter lever that I had removed and TIG welded it to the Factory short shift handle. I then heated up the lever portion of the shifter and bent it back about 1 1/2 to 2 inches. Once that was done, it felt perfect and I didn't have to lean forward. I then ground down the weld, applied a little body filler, sanded and painted the handle black.
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 04-19-2009, 08:39 AM
