Spedo Wiring Question
Can anyone confirm what these 3 wires are for? They are in the center tunnel and I think they are for the spedo. It stopped working after I purchased the car and when I looked into the tunnel I seen that the PO must have used the clip to disconnect the odometer to keep the miles from not being tracked. Shady bastard
![]() Anyway need to know what the 2 yellow wires are for and if the Brown wire is suppose to be connect to the transmission sensor.
Member 911 Anonymous
I think the Yellow are Foot Blower Heater Wires connected to the Red Levers. What year is your baby?
Pull the Speedo from the console and see if it has been disconnected.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-18-2009 at 11:28 AM.. |
It is an 81SC. Heat has been removed so makes since why they are not connected. From what I can see is that the brown/white wire was stripped down and the red wire was clamped to the open area. I am going to remove it solder them together
