-   -   After a Backfire, What Could be Wrong? (http://forums.pelicanparts.com/porsche-911-technical-forum/469659-after-backfire-what-could-wrong.html)
Paulporsche 04-18-2009 11:43 AM
During an incorrect WUR testing procedure, I heard an extremely loud "SNAP" sound coming from the engine area. After that, the engine wouldn't start. Previously, the engine started, but ran w/ rich symptoms because the WUR wouldn't "warm up"/raise the CPs.
The likeliest scenario seems to be that I blew the airbox, as I had tried to start the engine w/ a CP that was now set too high for the temps . Even though I had a functioning popoff valve, the backfire apparently was too extreme.
Since I won't be able to do a partial engine drop to check the box until next week, I have several questions in the meantime:
1. What else can I check? The sensor plate and the rubber boot above seem fine, and I've felt aroud the box, components and hoses.
2. Could there be internal damage to the engine, say a broken valve spring or other component, that is causing the engine to fail to start?
3. Could the attempts @ restarting cause a hydro lock? Over time, will any excess fuel drain from the cylinders?
Bill Verburg 04-18-2009 11:54 AM
Sounds like what happens when you blow a CIS airbox
sailchef 04-18-2009 11:59 AM
From my exoeriences I would double check around the pop off seal first. If its the toilet seat type especially. Mine had a hairline crack in the sealant holding it in (caused by a very loud backfire). It seemed ok and felt very secure but was sucking just enough air to screw things up.
sailchef 04-18-2009 12:04 PM
Violent backfire
sorry for the repost but I couldn't find this earlier
http://forums.pelicanparts.com/porsche-911-technical-forum/434636-help-violent-backfire-now-engine-runs-rough.html?highlight=sailchef
Wayne 962 04-18-2009 12:16 PM
99.9% - there's something that got blown off that you just can't see. When you find it you will say "oh, that's what it is". It's probably creating a huge vacuum leak in there. Keep looking around. With a popoff valve installed, it's unlikely that your box blew up, but you probably blew off a hose or something...
-Wayne
Paulporsche 04-18-2009 04:02 PM
I just went out to check for hoses, etc. Still couldn't find anything, and all the airbox screws look tight. The popoff valve looks really secure too. I'm going in w/ a flashlight tomorrow and check further. Maybe there's a hairline crack somewhere I'm just not seeing yet. And I think I'll try sealing around the popoff valve just in case.
BTW what about my other questions:
Any chance there's an internal engine issue? A bent valve or broken spring?
What about hydraulic locking from excess fuel? Will the excess fuel eventually leak past the cylinders into the oil?
Paulporsche 04-19-2009 07:49 AM
Thanks to fireant for posting the MM (I know) video in the "Air box help" thread.
Just a bump to see if there are any comments re internal engine damage and hydro locking.
al lkosmal 04-19-2009 08:29 AM
recheck your popoff valve. Even if the bonder is still ok, make sure that the lead is closing all the way and that the o-ring seal under the lid is present and working.
regards,
al
ossiblue 04-19-2009 08:33 AM
Paul,
This may sound obvious, but don't forget to get a mirror and look in back (actually front) of the engine--between the firewall and the CIS. There are vacuum hoses there that could be cracked or blown off. Also, are you certain you are getting spark? I ask because even with a blown box, you should be getting some brief running from the cold start injector--unless that has been disabled also.
Turboo934 04-19-2009 09:12 AM
I had a metering plate get bent once even with the pop off valve in place. I've also seen them blow a hole on the bottom side of the air box. Good luck.
Paulporsche 04-20-2009 06:07 AM
Thanks, guys. I noticed Davyboy removed/replaced his airbox w/ the engine in place. I'm going to try that first. If it gets too tricky, I'll do a partial engine drop.
Wayne 962 04-20-2009 06:13 AM
You can remove one of the vacuum hoses and pull a vacuum on it (even by sucking). If there is a leak, it won't hold vacuum...
-Wayne
Paulporsche 04-20-2009 06:44 AM
I'll try that. Thanks, Wayne.
