-   -   G50 diff case ? (http://forums.pelicanparts.com/porsche-911-technical-forum/469678-g50-diff-case.html)
JIM DRAGTEAM 04-18-2009 01:50 PM
G50 diff case ?
Hello forum!
Simple question (I hope) !
I buy a 1989 g50 off a carrera.
The rear section (where it bolts to the engine) is damaged (cracked)
The seller give me an extra rear section from a 1990 c2 along with the diff cover.
Will these fit together ?
Is it a DIY job or a pros only job ?If so any recommended shop in NYC area ?
JIM DRAGTEAM 04-19-2009 01:26 PM
Anyone guys ???
Rgds,
Jim
Por_sha911 04-19-2009 02:08 PM
I wish I could help you. IIRC there have been discussions on previous posts about mating later model G50s to earlier cars. Check out the search button.
lite75 04-19-2009 02:09 PM
You need to check the ring and pinion settings, unless you have the tools it's a shop only swap.
KTL 04-19-2009 05:47 PM
The parts will fit. But like lite75 said, you've got to check the pinion depth, differential carrier bearing preload, and ring & pinion backlash when you reassemble. Specialty tools and/or experience are key to proper assembly and operation.
