zugelassener benutzer
Steering - what's wrong
I noticed it was very slightly nothcy then today if seems to freeze up slightly at slow speeds turning and it happens not too far off center. Is it a u-joint, bushing, not sure. At about 30-45mph it's smooth if I do a light weave back and forth and I do notice it more the more I turn. It's not consistant either. The only place I looked was in the trunk through the access panel and everything appeared and moved OK. Also, safe to drive until fixed?
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing 7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo 32C #7 |
gjs
Check your tie rod ends. Lift the front end to do so. Check play and turning with your hands on the the front tire.
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff 2015 Cayman S 1948 Willy's Overland Jeepster 2013 Chev Sub 2004 Nisson Xterra Last edited by glennspiegler; 04-19-2009 at 02:57 PM.. |
Spray some WD40 on the U-joint in the smuggler's box. They sometimes get dry and notchy. If it fixes it, oil it a bit once a year and it will be fine.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
this happened to me - - it was the lower steering shaft bearing - the one that sits under that gold colored strap in your pics. saved me alot of time figureing that out instead of trying to take off the tie rods and all that stuff.
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=911-347-029-00-OEM&catalog_description=Steering%20Shaft%20Bearing%2C% 20911%2F911%20Turbo%20(1974-89) there it is on our host's website! - - when i took it out of my car it basically fell apart in my hand!
2007 997 1998.5 Ram 2500 Cummins Last edited by Milo2361; 04-19-2009 at 07:49 PM.. |
