BP8EVX engine 911 T 2.0
Hello
i have an engine 911 T 2.0l (weber 40 idtp carbs) rebuilt like the original expected the pistons because i put six JE pistons 80mm ratio 9.5 with cylinders in biral. i put NGK BP8EVX plug. is it good model? thanks jerome |
Jerome, no. BP8EVX is a platinum racing plug, $14 each. Platinum plugs don't work in 911s.
Get yourself the regular BP7ES, they are under two bucks a piece.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
bp8evx
hello john
thanks for you answer. can i put a plug more cold than the original bp7es like bp8es because i have more compression ration than origin (9.5 with je pistons 80mm instead of 8). what happened if i put a bp8evx or bp7evx ?? or do i must put the bp7es. thanks |
