dazed and confused
Is there a shorter spark plug tool?
After reading all the posts on sparkplug removal methods, I ordered the wrench from the toolkit (no toolkit with the car) from a reputable salvage yard. However, despite many attempts, it's just too long for me to maneuver. I resorted to articulated sockets, locking extensions, and hoses (Pelican posts are extremely helpful!). Took a while, but once I got the "feel", what started as a chore became fun.
However, now I've got this wonderful tool that I can't use....see pictures...were they all this long? It's missing the knurled tip that others spoke of in previous posts....could it be aftermarket (says "Klein", which I thought was factory...) Or is it just me....curious. Watch for it in the for sale forum.... ![]() ![]()
89 Carrera 3.2 Targa 2011 BMW 335d 2013 BMW X3 3.5 80 911 SC Weissach Coupe (Sold)
Almost Banned Once
There is a shorter version of that tool. It's less than half the length of yours but otherwise very similar.
- Peter |
That tool looks like the one for a 912 maybe? Definitely way too long for a 911. Contact the salvage yard and see if they'll exchange it for the correct tool.
This one from the tool kit that came w/ my '72 was the best I ever used
Friend of Warren
That sure isn't a 911 tool, more like a 944?
Kurt V No more Porsches, but a revolving number of motorcycles. |
Mine looks just like Bill V's. It is a great tool to have. Even at it's shorter length, there was a plug or two that took some maneuvering to extract while attached to the tool - there's no way you could get to any of the plugs with the tool in you photo!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
This is the tool that came with the later 911's, I know at least 77 and newer. The shaft flex's to make it easy to remove/install in the tight area's of the 911.
The "fixed" shaft tool of Bill V's came with the early cars. I have no idea where the tool you got came from, but it was not a 911. Possibly, as stated above, a 356 or 912...
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S Last edited by timc; 04-22-2009 at 07:50 AM.. |
Designer King
Looks like a 944 tool.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
John,
Yours is definitely one from a 944. The "flexible" 911 tool (as shown in timc's) post works well for the later cars (84-) & turbos but the earlier "fixed" is the best one I have ever used on the earlier cars. The fixed one really gives you a lot of feel which really helps when it comes to avoiding cross threading the plugs.
FC '73 911 Track Car '99 996 Daily Driver '93 968 Wife's Car '05 Cayanne S Family Car |
dazed and confused
Thank you all for your help!...now back to the salvage yard..wish me luck!
Autodidactic user
This one is definitely the best. I only wish that they had designed it to attach directly to a 3/8 ratchet instead of using a 10mm hex.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
not that hard to weld a 3/8 end on one. 5 5/8" is the magic length. been using this one for many years.
Sherwood |
Hazet
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
dazed and confused
Recognition of two suppliers...
Contacted the salvage yard that originally supplied me the wrong tool (top of photo). Sent pictures from the responses I received on Pelican...this forum is TERRIFIC. After much searching, they located the correct sized tool (bottom of photo). No charge replacement; this after a year of my first receiving tool. dc Automotive...very responsive and honorable! Thank you to all.
