christojen's Avatar
Brakes sticking grabbing - have searched please help
Hi guys i have searched the forum to check out what might be causing my brakes to stick on in my 1977 911.
the car sat for a long while, and intermittently has teh problem of the brakes sticking on after using them whilst driving. I understand it could be a range of things, but starting with the flexi hoses would be a good idea yes?
I should add that even when it does occur, it always (so far) eventually goes away again. When i dont drive the car for a while they are freed up.
does this sound like swollen brake lines or is it more likely calipers?
All advice appreciated.
Chris in Aus
Old 04-21-2009, 07:00 PM
djpateman's Avatar
By the symptoms, I'd guess the rubber flex lines are swollen internally. They are usually good for up to 15 years, but sometimes less.
I'd be inclined to freshen up the calipers at the same time.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-21-2009, 07:21 PM
On my 88 my gas mileage increased when I put new hoses on it. The brakes made a groaning noise when I would pull away from a stop.
While you have it apart you may as well throw a caliper kit at it. There may be crap in there also.
Rick
88 Cab
Old 04-21-2009, 07:25 PM
its the hoses. just change them
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 04-21-2009, 07:41 PM
christojen's Avatar
thanks guys, yeah i figured it was the hoses, is it simply a case of pulling them out and putting in new ones, then bleeding the brakes?.
Any other steps involved, like do i need to empy the master cylinder resevior or anything like that?
Chris
Old 04-21-2009, 09:59 PM
thats it. if ur brake fluid hasnt been changed in a while it wouldnt be a bad idea to get a turkey baster or something and suck it outa there. carefull when bleeding the brakes if u use the master cylinder pump away method, u can ruin it by pushing the pedal to the floor, unless its really new. if its old the piston screws up the seals in the back of MC.
Jason
81 SC
97 328is
Old 04-22-2009, 02:49 AM
Senior Advisor
James Brown's Avatar
interesting, my rear brakes are sticking a little (noticed it when l tryed to push my car-very hard) but l changed out the old lines with new SS lines from our host and New fluid about 14 months ago.
Lthink it's the callipers that are sticking not the hoses. anyone have trouble with the callipers sticking due to the seals?
08 Cayenne Turbo
Old 04-22-2009, 10:43 PM
its kinda hard to tell, its kind of a crap shoot. rest assured u will rebuild that car 1 part at a time
Jason
81 SC
97 328is
Old 04-22-2009, 11:50 PM
Senior Advisor
yup best get on it, don't want to burn up the brakes
08 Cayenne Turbo
Old 04-22-2009, 11:53 PM
Rouxzy's Avatar
Had a similar issue with mine. The claipers were sticking, (stuck) and the brakes were not working well. Rebuilt calipers and now I have put you thru the windshield stopping power.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 04-23-2009, 05:03 AM
Home of the Whopper
If you have no idea of what was done to your brakes, it is a good time to rebuild all the calipers and replace the brake lines. The rebuild kits aren't that expensive. Rebuilding calipers isn't that hard, but it is dirty. Some places will rebuild them for you.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 04-23-2009, 08:33 AM
djpateman's Avatar
The original post said that the sticking went away with time, this indicates swollen lines.
Always sticking brakes would indicate calipers are the problem.
In any case, neglected braking systems require a lot of attention to return to service.
Addicted since 1975
Old 04-23-2009, 12:55 PM
