1982 911SC
Semba's Avatar
Turn Signals
I had a bad socket on the original turn signal relay from previous owners improper placement and being crushed by the deck lid arm. I cut away the rubber socket one wire at a time and marked all the wires according to numbers on the relay. Now when I use the turn signal switch, both dash indicators flash as if the flashers are on, but the actual turn signals are working appropriately left and right. The flashers also work correctly, but then no dash indicators at all? What I currently have is
49a Black w/ green and white strips
49 Red w/ white stripe
C Blue w/white stripe
31 Brown
What did I do wrong?
Old 04-25-2009, 06:15 AM
FenderBender's Avatar
Sounds like a bad ground. Early cars are notorious for this problem. I am not sure if all years were plagued with this problem? I fixed mine today and will be making a post on this.
I Found My Double Arrow Demon Today. (turn signal arrows)
Mike
'99 Isuzu VX, 2005 Audi A4 1.8T Quattro
'96 BMW 328ic
'73 911T Targa SOLD
www.flickr.com/photos/fenderbender813
Old 04-25-2009, 05:40 PM
