oil pressure stay in 5 bars
Car is 87 3.2 carrera, turn the ignition on without crank the motor, pressure gauge shows 5 bars, fire it up also stay in 5 bars any idea whats going on
? thanks
Old 04-25-2009, 11:15 PM
The wire on the oil pressure sending unit might be loose or disconnected. Carefully and thoroughly clean terminal post and wire plug making sure there is solid contact between the plug and terminal. That's what fixed mine.
1987 Carrera 3.2
Old 04-26-2009, 06:17 AM
Make Bruins Great Again
Por_sha911's Avatar
This has been discussed within the last two weeks. Do a search for a ton of good info on how to diagnose and replace the sender if needed.
Joe
Old 04-26-2009, 12:40 PM
Registered Abuser
MT930's Avatar
I just went though this problem My sender was bad.
Pegged Oil Pressure Reading?
If your sender / sensor is indeed bad read this thread it will save you alot of trouble.
Question on replacing the oil pressure sender
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 04-26-2009, 01:21 PM
