amp/volt gauge--rectangular shaped?
anyone know of an amp or volt gauge that would fit here?
http://forums.pelicanparts.com/uploa...1240970348.jpg |
You "might" find some custom digital unit but I doubt it.
"Back in the day" I recall seeing (and actually using) small 'edgewise' panel-mount meters.
Some of you youngsters probably aren't familiar with the wide variety of analog meter that were once used. ;) Not at all a bad idea to mount something like that in this spot, but the mounting depth might be an issue. I'm searching; so far the 185-series Yokogawa looks promising. http://forums.pelicanparts.com/uploa...1240972201.jpg |
Update:
Yokogawa 280 series is available in sizes as small as 1 1/2" size. The actual bezel size of the smallest vertical meter shown below is 0.77" wide, 2.075" high, and the unit requires well over 2 inches of mounting depth. http://forums.pelicanparts.com/uploa...1240973488.jpg |
| All times are GMT -8. The time now is 08:54 PM. |
