Brorag
Brorag's Avatar
amp/volt gauge--rectangular shaped?
anyone know of an amp or volt gauge that would fit here?
Old 04-28-2009, 06:59 PM
sudo apt-get purge 930
equality72521's Avatar
You "might" find some custom digital unit but I doubt it.
--clutch-monkey
Old 04-28-2009, 07:07 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
"Back in the day" I recall seeing (and actually using) small 'edgewise' panel-mount meters.
Some of you youngsters probably aren't familiar with the wide variety of analog meter that were once used.
Not at all a bad idea to mount something like that in this spot, but the mounting depth might be an issue.
I'm searching; so far the 185-series Yokogawa looks promising.
Old 04-28-2009, 07:31 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Update:
Yokogawa 280 series is available in sizes as small as 1 1/2" size.
The actual bezel size of the smallest vertical meter shown below is 0.77" wide, 2.075" high, and the unit requires well over 2 inches of mounting depth.
Old 04-28-2009, 07:52 PM
