leverpuller's Avatar
lopes at idle
the old girl lopes at idle... 82-911 idle drops to 400 then back to 900. engine oil temp around 175 which in not fully warm. what is controling the idle at these temps. Hope fully it's not a hand full of things. If so, when the floor lift arrives, it will help save my back....American equipment..pmx something arriving any day. Maybe if I changed everything that's electrical with air on the intake, I will have solved my problem..What does the board thinks?
Old 05-01-2009, 12:44 PM
Jupiter 911
bklyn's Avatar
Not sure, but would like to see the lift you bought!
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 05-01-2009, 12:48 PM
go to american equipment on the web
Old 05-01-2009, 01:08 PM
Designer King
Paulporsche's Avatar
Search "hunting idle". It occurs quite often in CIS cars. Usually it is a sign of a mixture that is too rich.
Did it happen recently? Did you or anyone do any work on the car?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-01-2009, 01:55 PM
