1974-1977 Sway bar Question.
What is the differience between 1974-1977 and 1978-1985 Sway bars. Well they interchange. Thanks.
Old 06-29-2010, 07:18 PM
IROC's Avatar
IIRC, the 74-77 US cars were all imported with 20mm front, 18mm rear bars. RoW cars had a 16mm front and no rear bar. The later bars are a direct bolt-on, but I would recommend going with the later Carrera 22mm front/21mm rear bars if you're going to go through the trouble to swap them...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 06-30-2010, 04:17 AM
My '77 UK has 18mm rear. 20mm front.
Old 07-01-2010, 04:43 PM
Look for 86-89 bars. They will interchange with the use of the later bushings. The biggest challenge will be the rear. 74-77 cars used a 'cup-and-ball' design to attach the drop link to the trailing arm, where the 78 and later cars have a bolt on drop link. The easiest solution is to go with aftermarket drop links made by tarret (I think Pelican sells them) that bolt to the spring plate instead of the trailing arm. Other options are: 1. modify the 74-77 drop link to bolt to the later sway bar, or 2. replace your trailing arms with those from a 78-89 car.
Old 07-01-2010, 05:20 PM
I think you can remove the droplink "mounting knob" on the early trailing arm and use the later bolt on droplinks . I don,t think you need to change trailing arms
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 07-01-2010, 06:24 PM
Thanks everybody I have a 1978 set up to put on the car. When I bought the car the rear sway was missing but it did come with one. Thanks Again.
Old 07-01-2010, 07:08 PM
Post again after you put the rear bar on. My '75 is missing its rear bar, thinking about putting one back on. High speed turn-in is pretty much non existent.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 07-02-2010, 06:01 AM
