-   -   RSR sytle car: Part it out or sell as a roller? (http://forums.pelicanparts.com/porsche-911-technical-forum/471876-rsr-sytle-car-part-out-sell-roller.html)
John Schaefer 05-05-2009 05:09 AM
Originally Posted by tangerine911S (Post 4644984)
Wait...a set of 9 and 11 x 15'' wheels and those brakes are worth $30K!?!?
I couldn't get a firm idea on a price for the complete brake system, so I sold it to someone in Switzerland for $15K.:D Most of the motor, the transmission, and the wheels will go to my white 3.0RS clone.
http://forums.pelicanparts.com/uploa...1241525346.jpg
onboost 05-05-2009 10:54 AM
Those pieces should make a nice addition to the 3.0RS clone. Nice Car!
Paul
John Schaefer 05-05-2009 08:56 PM
I thought I'd share some interesting photos of the rear banana arms. The guy that purchased the brakes didn't want them as they are not real RSR items, but it's intriguing to see the lengths to which the person that set this suspension up went to in order for the brakes to fit (not too many people could weld aluminum like this 25 years ago compaired to today). I think these aluminum arms were original to this 911S? The First photo is of the real RSR stuff, the other two are what I now have to find a new home for.
http://forums.pelicanparts.com/uploa...1241581467.jpg
http://forums.pelicanparts.com/uploa...1241581506.jpg
http://forums.pelicanparts.com/uploa...1241581588.jpg
I also removed the air filters off the stacks... wow! :eek: What a difference.
http://forums.pelicanparts.com/uploa...1241581844.jpg
http://forums.pelicanparts.com/uploa...1241581908.jpg
CBRacerX 05-06-2009 06:07 AM
Sign me up for that slide valve! Sexy...
juicersr 05-06-2009 07:01 AM
Wow, this is some really cool stuff.
Neat details on those trailing arms... giving me some ideas
Is this a 2.8 or 3.0? I don't think there is a better sounding racing engine ever made than the slide valve RSR motor, even better than the flat-12.
John Schaefer 05-08-2009 12:25 PM
Decided not to put first generation Turbo suspension and brakes on and went with '74 Euro Carrera stuff. Here are some photos of it installed on the rear. Not quite the same as before (but we did keep the adjustable spring plates and swaybar), no?
The motor will be coming out as the distributor/ignition and slide valve injection systems are sold.
http://forums.pelicanparts.com/uploa...1241810489.jpg
http://forums.pelicanparts.com/uploa...1241810603.jpg
John Schaefer 05-13-2009 04:39 AM
I am tearing the engine down now. The block ends up being a first generation no numbers factory 3.0 Turbo replacement case. Interesting as it takes the 70.4mm 2.7L crank, but has 86mm head stud spacing. I am told that the 3.0 RSR (83mm head stud spacing) heads have enlarged head stud holes from the factory that allow them to fit. Same situation is seen in the 2.8mm RSR head (which has 80mm head stud spacing), which can be used on the 3.0RSR due to the same factory oversized holes.
http://forums.pelicanparts.com/uploa...1242214323.jpg
DVO 460 injectors
http://forums.pelicanparts.com/uploa...1242214396.jpg
Solid rockers and RSR cam housing
http://forums.pelicanparts.com/uploa...1242214480.jpg
3.0 RSR heads date coded 8/73 and 98mm Mahle pistons
http://forums.pelicanparts.com/uploa...1242214590.jpg
