-   -   Need to drain trans before removing mechanical tach? (http://forums.pelicanparts.com/porsche-911-technical-forum/472220-need-drain-trans-before-removing-mechanical-tach.html)
DSouth 05-02-2009 08:52 AM
Hi all,
I'm doing my first engine drop today. I was just about to remove the mechanical tach connection at the trans, and it occurred to me that I might need to drain the trans before I removed that.
Can anyone confirm that I do need to drain the trans before removing the mechanical tach connection?
Thanks!
Bobboloo 05-02-2009 09:31 AM
You do not need to drain the trans to remove the tach drive.
TRE Cup 05-02-2009 10:40 AM
Bobby is correct in that you do not need to drain the trans to remove the SPEEDOMETER cable drive ;)
Bobboloo 05-02-2009 03:20 PM
Dooh!
Then again, technically speaking, you don't need to drain the trans when removing the tach drive from the dizzy either. ;)
DSouth 05-02-2009 09:49 PM
Doh! Speedo is right. Thanks for interpreting and for the super fast response. I did successfully complete my first 911 engine+trans drop today.
I'll post some pics over on my other rust remediation thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/467001-my-rust-remediation-project.html
