Refinishing Fuchs
I'm going a quick polish and paint of my Fuchs. They are in very good shape now, just need a little clean up.
My question is once the centers are painted, do I clear coat the entire wheel including the polished lips or just the centers? Thanks. Jeff
Jeff '04 Cayenne S Hauler '98 993 Cab '74 Euro Carrera - SOLD '91 944S2 Track Car |
I just had the centers done. I opted to leave the lips unfinished because I was scared it would dull the shine. Mothers polish and powerball every few months and they still look good as new. I also wax the centers to keep the shine up. Try to post some before and after pics to see how they turn out.
Good luck. ![]()
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS 1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE. 2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK" |
I didnt clear mine. I just used Rustolium Semi Gloss paint....that was about 3 years ago....
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
dkbautosports.com
fuch wheels should not have a gloss clear on then if your looking for an OE appearance it has a mat sheen . over the 30 plus years in the body biz . i have fond a perfect match with looks (peal) and the OE gloss . its called SEM Rust-shield color # 3809 mix it 8 parts black to one part of the rust-shield hardener . you can spray it over bare metals and aluminum . it also has the same mil thichnes as the OE finish . as for clearing the buffed aluminum lip you will need a clear made just for that . your every day clears will peal off in no time ! Eastwood.com sells a clear for clearing aluminum . i use it alot ! it works good ! just use it on dry days .as for clearing the lip or not ? you will have to decide that . it looks more OE if you clear them . when you put clear over buffed aluminum it does take some of the shine away . some people like it to look like chrome . its all up to you !
Those wheels look great. Nothing like a clean set of Fuchs.
Thanks for the tips! I was going to use everyday clear. I did not know that there was special clear for aluminum. I'll source some Eastwood and see how they turn out. I do want more of an OE look so I'll go with a satin or mat black center.
