Differential Carrier Bearing Races
Can anyone tell me the method you used to remove the OUTER races from the case and cover? I pulled the cover seal and don't see much room for a blank or a puller.
Old 05-04-2009, 06:11 AM
abit off center
cgarr's Avatar
Should be able to catch the edge with a punch, might have to special grind the end.
______________________
Craig
G2Performance
Old 05-04-2009, 06:24 AM
Peter Zimmermann's Avatar
+1. Brass if possible.
Keep the Shiny Side UP!
Pete Z.
Old 05-04-2009, 08:44 AM
rnln's Avatar
Drco and I just did it last weekends. I used a big screw driver to punch them out from the other side.
Fat butt 911, 1987
Old 05-04-2009, 10:12 AM
