-   -   Another RSR build - The begining (http://forums.pelicanparts.com/porsche-911-technical-forum/472524-another-rsr-build-begining.html)
911st 12-13-2010 06:17 PM
If I may, how is the gas pedal configured / connected?
Are the pedals closer to the driver than stock?
Thx.
Originally Posted by wax105 (Post 5602109)
Samujr 12-14-2010 01:56 AM
Impressive build, kind of my dream!
I'm planning to put G50 box to my 73 project someday. I have tried to find reasonable priced G50 pedal setup, but no luck so far. As I would like to get proper balance adjustment too, Tilton pedal setup could be best option. Could you share some details: Are you using 600 series pedals? Looks like 680 model to me. What about master cylinders, size and are those 75 or 76 series? Need to be very short due location. Tilton parts are almost double price here in Europe :eek: so need to order from US.
wax105 12-14-2010 07:40 AM
911st
That picture is from the first day I got the pedals, they are not placed or bolted. I'll get you a fresh pic, yes the pedals are closer and more to the left from the originals. As for the accelerator, it's not done yet but a simple custom lenght cable or retrofit something adequate. Tilton sells an adjustable throttle linkage system that basicaly lets you tune the rate at which the throttle will be opened. Havent decided if I'll use it but I think it could be nice...
http://forums.pelicanparts.com/uploa...1292340260.jpg
A small tab on the tunnel to stop the cable housing and the cable attached to the throttle cam. Won't be done right away but I'll definently show you guys my solution once I've dealt with it.
Samujr
I'm using the 680 series pedals, they are about 500$ depending on where you get them, no m/c, bias nob or throttle cam. As for masters, the 75 and 76 series are essentialy the same apart for the fill cap, I have 75s.
In my case, I dont have to worry about street use or looking original being a dedicated track car. If someone simply wanted dual brake m/c, I think there are easier and cheaper option out there. Doing a single brake pedal w/dual m/c adapted to the factory pedal box might prove a better option for some...
Samujr 12-14-2010 10:38 AM
Thank you for the details. Good to know that 75 and 76 are basically identical. I do not need billet/aluminium reservoirs so 75 should be fine. And yes, 680 series 3 pedal setup is around £500 from UK what is like $800. Same type of pricing on master cylinders. Those dual setups like Fabcar still uses Tilton master cylinders and it aint cheap either, but fine if you want to use std pedals.
Now, how did you calculate suitable master cylinders sizes?
Samu
Samujr 12-15-2010 01:38 AM
Found good thread regarding dual mc setups. Bill Verburg, as usual, shares his huge brake knowledge:
Dual-m-cs-size-recommendations
wax105 12-15-2010 03:35 AM
Samujr
Bill V is certainly an authority on brakes! I got in contact with Tilton engineering department, they asked me some questions, seemed to plug the numbers in a calculation tool and voila... He did say that they dont do this anymore for customers. Dont want to be liable for making that choice, people didnt like the proposed m/c and would call back expecting a trade or refund. The calculation takes to many factors to get exactly right but you can get close enought that its one size up or down...
At about 100$/per and a selection of about 10 sizes, worst case scenario, you spent 1000$ getting it right!! :p
No seriously, the engineers comment was:
" Most all 911s I have sized requierd 7/10 m/cs for about 100lbs foot pressure for lookup..."
In the end it comes back to driver preference!
wax105 01-03-2011 08:07 AM
The Monster is alive!! You are looking at one happy camper...
http://forums.pelicanparts.com/uploa...1294070498.jpg
While the friends and family were celebrating in the house on January 1st, I was celebrating in the garage! ;)
I finally got all the wiring and connectors figured and she fired right up! Now that I know what I need and dont need, I will clean up this mess of electrical and oil lines and sort it all out.
http://forums.pelicanparts.com/uploa...1294067410.jpg
http://forums.pelicanparts.com/uploa...1294067461.jpg
http://forums.pelicanparts.com/uploa...1294067598.jpg
A word of advice to those that will be using the PatrickMotorsport flywheel, I had to modify the crank sensor bracket to get .8mm gap. I chose to shave the sensor mounting face of the bracket and not enlarge the adjustement hole and change the attack angle. Mine needed about 1.3mm closer, check it well before you attempt a start, its nice when it fires right up on the first try...
So my next step will be brake and clutch lines, accelerator cable and then it all comes apart again for fab engine bay tins, cutting of bumper supports, bulkhead trims and grommets and finaly door bars!
Still alot of work ahead but its definitely a car now... :D:D:D
KTL 01-04-2011 09:23 AM
Congrats on the progress Carl. Looking good as usual. Man, I didn't realize how big your oil tank was from previous pictures. That sucker is BIG. How did you mount the suction/supply line to the engine? Is it the lower of the two silver-sleeved lines?
One thing I noticed is where you placed the G2X brain. I was thinking of putting mine there too. You think you'll have a hassle getting to the card port to download your data? Also was thinking of being able to see the LEDs in case of diagnosis. Not a big deal. Just wondering your thoughts.
I see you have a similar fuel cell as my Sport 15 gallon. These are nice cells for the price, no? Curious how you're planning to mount it. Mine is suspended from the floor with two lengths of square tubing across the trunk and then bolted down with two cross pieces. Had to add some "U" sections underneath after I discovered lack of support under the old cell allowed it to signficantly droop and distort the steel containter.
http://forums.pelicanparts.com/uploa...1294161657.jpg
I'd like to build onto my cage like you have done, so i'm interested to see how you mount the cell. I think it'd be fairly easy to build the reverse of my installation, with the cell on the floor. I don't like my install, given that the cell is "floating" above the floor and obviously puts weight higher than it needs to be.
IDGAF27 01-04-2011 10:06 AM
Great read to start a new year.........
Plavan 01-04-2011 10:29 AM
Just my .02 cents and I'm not trying to hijack. If you plan on changing your fuel cell mount, I would consider moving those two fuel pumps toward the center of the car instead of them in the front. Not really a good spot for a possible front end collision.
Great build!
brettm69 01-04-2011 01:12 PM
Great build, the RSRs have always been one on my faves:)
You do some superb fab work!
Brett
KTL 01-04-2011 02:09 PM
Chad,
I agree the pumps are in less than ideal location. That's how it came built, and I felt the same way as you when I first saw it. I have to replace some fuel lines due to age, so i'm working on re-doing the layout. Probably end up re-doing it a second time when it comes time to install forward mounted oil tank......
wax105 01-04-2011 06:16 PM
Kevin,
You're right the oil tank is huge, 5 gallons, I'll keep it about 3/4 full. The deal I got was to good to pass up, I would have got a 4 gallon if I was buying new... It will do just fine for the application!
Yes the lower oil line is the supply, I got a metric to -16 adapter fitting and used a 90deg hose end. I'll get you some pics if you like...
Good point about the G2X, I used industrial strenght velcro to attach it to the tunnel. This will allow me to access the memory card and status lights, I think its the best place for it. Those velcro strips are really very strong, its not moving unless I want it to.
As for the cell, I have a 12g, sportsmans are definitely the best bang for your buck. Drop in models are ridiculously expensive and for a track application they are of no value I think! Go back to post #66, you'll see the craddle at the bottom, its resting on the cage in the front and I welded some tab at the back. The craddle itself is welded in place, I still need to decide on the way I'll attach the alu. straps that will hold it in place.
I agree with Chad about the placement of your pumps, not ideal but I dont think its major. As you said, take care of it when you get in there.
Brett,
I understand my friend, this is what I dream about at night!!
http://forums.pelicanparts.com/uploa...1294193487.jpg
Thanks for nice words guys!
KTL 01-05-2011 08:35 AM
Only reason I asked about the tank supply line is because i've heard that its a good idea to run that line as straight as possible. I suspect it has something to do with ensuring best possible flow back to engine and avoid making the pump work harder to scavenge oil from the tank? Usually that line can be nearly level since the tank outlet fitting and the engine inlet fitting are at approximately the same height. However connecting those two points in a level manner is easier said than done, considering other stuff like trailing arms can get in the way!
I had my Traqmate mounted on the center tunnel where the handbrake used to be. Nice location but easy to damage if you put your hand on the tunnel area to get in/out of the seat. I agree the super duty velcro is tough stuff. Use too much of it and its like you glued the thing in place! A few semi-narrow strips is all you need to mount something light like the G2X brain or the ECU.
Looking forward to seeing your hotrod go. Some in-car video shares will be a must to hear that thing scream! :D
wax105 01-05-2011 09:43 AM
Good point about the oil line Kevin! The trailing arm is kind of in the way but I might be able to straighten it out some more... I figured the smuggler box oil tank installs would put more stress on the pump. The point you make is very logical, I'll look in to it!
DW SD 01-05-2011 09:52 AM
Carl,
This is really a beautiful project. Great job (again)!
A buddy of mine has the front trunk mounted tank, but uses -20 or -24 for the feed line. It is laid out level through the car, back through the firewall and to the inlet. He posts as Ted on this board and suspect his setup is detailed in what is likely the longest car build thread on Pelican (maybe short of Matteo's).
It might be worth looking into the large hose? Or at least checking with a shop like Patrick Motorsports on how they do these. Hate to find out the hard way that there wasn't sufficient oil flow.
That pedal assembly and throttle, especially is really impressive.
Thanks for all of the photos!
Doug
KTL 01-05-2011 10:11 AM
Here's SmartRacing's oil tank install recommendations. They're pretty good at sweating the details to make sure things are done right. Alot of what seems like overkill to us, has good reason when you hear the specifics behind why they decided to build it that way.
http://www.smartracingproducts.com/pdfdocs/154100_oiltank_front.pdf
That being said, Walt Fricke has had a front tank in his racer for like 20 yrs. and it was using a -12 supply line!
wax105 01-05-2011 05:43 PM
Kevin and Doug
I thank you both for your input, not the type of comments I take litely!
The second after I read Kevin comment (made sense to me), I contacted Andre at PorscheHaus for his opinion and sent him the pics of the line setups. He was not as worried about the height of the line as he was about the size. He says they had blown a few motors on high G tracks in the past because the supply line was to small. Basicaly -16 supply is ok but there is a risk factor, one I'm not ready to take, so -20 supply it will be... Now while redoing that line, I will route it straighter then it is now but dont have to obsess with it.
He did also mention that he likes to route the case overflow line as high up as possible (over the main hoop) and then back down. I wasnt going to run it that high!
This kind of stuff is gold boys, please feel free to comment anytime!
Carl
Plavan 01-06-2011 07:18 AM
Originally Posted by KTL (Post 5763693)
Chad,
I do however LOVE the fuel level gauge :) Way better than my hood prop/fuel guage.
KTL 01-06-2011 07:39 AM
Carl,
I've gotten conflicting opinions on the engine case vent line. Some like it high and others have said they don't. The ones that don't mentioned that they think putting it up high presents the opportunity to aerate the oil and it doesn't get to the tank as effectively? I don't know. I'd like to see for myself how the case vent line behaves by using a temporary clear hose- the braid reinforced stuff like you see in food industry. Then you could see how its traveling thru the hose and how much of it.
One thing i'm certain of is the case vent line MUST be vented to the tank and not to a catch can. Apparently the case vent can spit a pretty good volume of oil and a catch can would likely overflow and also deplete your oil supply.
Chad,
I can't take credit for the wood paint stirring stick and kite string fuel level gauge! I'm sure I would have overthought it and made something more elegant, wasting a bunch of time. But as I get older I am appreciating quick & simple solutions and I really like my previous owner's home grown fuel gauge.
What's also funny is the cell had a true ATL fuel gauge and sending unit (seen in the picture on the right side of the fill plate) that didn't work! :D I removed the gauge and incidentally had to cut off the probe of the sender because it wouldn't fit in the replacement bladder I had to buy- old one long expired. Anybody need a ATL fuel level gauge?
