915 - removing short shift kit
when i purchased my 74 Euro Carrera 2.7L, it came fitted with a short shift kit. the transmission was fully rebuilt by a reputable porsche independent shop.
however, i have not been 100% satisfied with the feel of shifting. for example, i must always slide it into 2nd before going into first in order to prevent crunching, shifting from 2nd to 3rd can be at times be difficult, 2 or 3 attempts may be required to get it into 3rd, and so forth.
some people have suggested that i remove the short shift kit and this will improve it.
if i wanted to go back to the original set up (ie long throw), what parts are needed and where can i purchase them?
what about a 915 wevo classic shifter? will this improve the feel of my shifts?
thoughts and comments welcome
thanks
Old 05-04-2009, 09:21 AM
At the track = great day
ChkbookMechanic's Avatar
I'd realign the shift coupler before blaming it on the short shift kit and see if that fixes some of your issues with not being able to shift into the gears.
A Wevo classic shifter is a short shift kit.
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 05-04-2009, 10:29 AM
short shifts suck. just find a complete used shifter unit and bolt it on.
206 637 4071
Old 05-04-2009, 10:43 AM
Adjust the clutch, too. Do what is called a basic adjustment, as opposed to just checking the clearance at the lever. You can search this forum for the details or look in the Pelican technical articles section. If you buy a complete shifter, get one out of a '77 to '84 model car.
JR
Old 05-04-2009, 11:10 AM
I have the same deal. luckily I saved the old shifter though the knob is stuck on the factory short shifter so I have more of an issue then I like
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-04-2009, 11:37 AM
where can i purchase a used (or new) unit?
Old 05-04-2009, 07:50 PM
the factory short shift is great. adjust clutch then readjust linkage. if you have weltmeister kit replace with factory kit
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-04-2009, 07:57 PM
Pelican used parts classified ad forum.
Porsche salvage yards.
PCA Panorama classified ads.
Some parts are available new but complete assemblies were never sold.
JR
Old 05-04-2009, 08:09 PM
grateful user
don gilbert's Avatar
shifting
i love my factory short shift kit, like a whole nother car.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-04-2009, 10:02 PM
The parts can be ordered from Porsche. However, individual parts are more costly than a complete kit. Also available from our host; also available new and used here and on eBay.
Sherwood
Old 05-05-2009, 02:54 AM
I have the WeVO classic in my '83 SC and am very happy.
Old 05-05-2009, 02:58 AM
Some parts are no longer available....
JR
Old 05-05-2009, 04:22 AM
Ruby911
ruby911's Avatar
I have some shifter parts from my 915 - I sent you a pm
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 05-05-2009, 04:25 AM
Daviboy's Avatar
Some comments
See my comments in red below
If your tranny has been truly fully rebuilt by a reputable shop I would ask if they have replaced syhncros etc
I think you will find a lot of 915 gearboxes suffer this issue with first. I reckon you need to pull the plate in the back middle on the floor in front of the rear seats and adjust the linkage and check your bushings.
Dont think so....
Just another comment change the tranny mounts I have heard this helps heaps
thanks
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 05-05-2009, 08:28 AM
