-   -   1968 911 engine number query (http://forums.pelicanparts.com/porsche-911-technical-forum/472548-1968-911-engine-number-query.html)
englishkid 05-03-2009 11:08 PM
my car, a 911L has a chassis # of 11810643 so definitely an L right?
the original engine number from porsche UK is 3080610
the engine in the car is 3180061 (901/07). according to the red book this is a sportomatic block. it's got weber carbs (and its definitely manual!)
is there anyway porsche get these things wrong, just strange to think that at some time the engine was replaced with an engine so close by date and so similar in the digits... any knowledge appreciated as usual,
ben
djpateman 05-04-2009 08:56 AM
Those engine numbers are off by quite a lot, and a different series besides. So Porsche UK is quite likely correct in the original number. What is the type # and build # of the engine you have? These numbers are stamped just a little further back of the serial # on the case.
englishkid 05-04-2009 11:05 AM
may i call you dj? thanks for the reply. here is everything:
vin#11810643
original engine number from porsche uk: 3080610
engine number stamped on the right hand side of cooling fan on engine in car: 3180061
other numbers phoned through from where the car is (60 miles away):
901/07
10388
901-106101OR
thanks again!
