1968 911 engine number query
my car, a 911L has a chassis # of 11810643 so definitely an L right?
the original engine number from porsche UK is 3080610 the engine in the car is 3180061 (901/07). according to the red book this is a sportomatic block. it's got weber carbs (and its definitely manual!) is there anyway porsche get these things wrong, just strange to think that at some time the engine was replaced with an engine so close by date and so similar in the digits... any knowledge appreciated as usual, ben
1968 911L 1970 911E |
Those engine numbers are off by quite a lot, and a different series besides. So Porsche UK is quite likely correct in the original number. What is the type # and build # of the engine you have? These numbers are stamped just a little further back of the serial # on the case.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
may i call you dj? thanks for the reply. here is everything:
vin#11810643 original engine number from porsche uk: 3080610 engine number stamped on the right hand side of cooling fan on engine in car: 3180061 other numbers phoned through from where the car is (60 miles away): 901/07 10388 901-106101OR thanks again!
