Designer King
Paulporsche's Avatar
Questions Regarding Battery Venting
In 20 yrs of owning my car I've never had a battery that required venting. My new one about to go in has 2 vent ports on the top.
I've searched but I haven't found any specifics regarding
How is the venting done? What type of hose is required? Can I plug 1 vent and vent the other? Is there already a hose on the chassis that I can connect to?Where does the hose exit the chassis?
Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-07-2009, 08:36 AM
scottb's Avatar
I have the exact same questions, but no answers.
Subscribing.
1984 Targa
Old 05-07-2009, 12:13 PM
Designer King
OK. I think I've found it. There is a clear plastic tube above the battery that disappears into the inner fender. I think that must be it. There is only one so I 'm going to get a T fitting @ my local FLAPS and hook up another line from the other side of the battery to it as well.
Paul
Old 05-07-2009, 01:40 PM
AutoBahned
RWebb's Avatar
you run a small hose from the vent to the exterior of the car
- keeps H gas out of the trunk; H gas is a real good explosive
Old 05-07-2009, 02:44 PM
