Gt3 spring rates?
Anyone know what the 996 or 997 Gt 3 spring or wheel rates might be?
Thx
Old 05-06-2009, 03:55 PM
Sway bar size's to if anyone knows them?
Thx
Old 05-06-2009, 03:58 PM
Navin Johnson
TimT's Avatar
Plain Jane GT3s or racing variants?
We have some heavy springs in our Lemans liveried GT3RS
#1100 rears..
'69 911 GT-5
'75 914 GT-3
and others
Old 05-06-2009, 04:20 PM
Bill Verburg's Avatar
Thx
I can provide that info for Cups and RSRs but not the street cars.
2000>Cup:
front 240 n/mm + 60n/mm helper, 5 pos 26.8mm rollbar
rear 260 n/mm + 60n/mm helper, 3 pos 20.7mm rollbar
2005> RSR:
front 4 step adj. 282 n/mm 293 n/mm, 317 n/mm, 345 n/mm rollbars infinitely adj. from the cockpit
rear 4 step adj. 282 n/mm 293 n/mm, 317 n/mm, 345 n/mm , opt 317 n/mm 333 n/mm, 352 n/mm, 375 n/mm
You can't directly compare these rates to 911 rates due to geometry differences
Bill Verburg
Old 05-06-2009, 04:40 PM
Plain Gt#'s.
Bill, cool info but I do not know how to convert to LBs per Inch. Can you help me w a conversion factor...
Thx
Old 05-06-2009, 08:07 PM
1 N/mm = 5.7 lb/in
Bill Verburg
Old 05-07-2009, 02:45 AM
I've got all the 993 rates
all in lb/in
Stock 993 is 150/200
M030 993 is 225/275
993 RS is 246/457
993 Cup 600/800
Bill Verburg
Old 05-07-2009, 02:51 AM
Bill,
That is cool info.
The RS numbers look a little funny with a very large split ???
Must run a really big front sway or no rear to make it work.
Thx.
Old 05-07-2009, 12:46 PM
285 / 385 was referenced by someone on another forum but do not know if 996 or 997 GT3 or if credible.
Bill I am guessing the RS 993 numbers must be 346/457???
Old 05-07-2009, 12:53 PM
Bill,
That is cool info.
Thx.
All the #s I posted come from factory documents, again don't read too much into these #s the geometry of the 911/964/993/996(7) suspensions is very different, to compare you would want to know the wheel rates.
Bill Verburg
Old 05-07-2009, 01:28 PM
Nope
I'm using 448/672
GT2evo uses adjustable rate springs like the 997RS all are N/mm, all use 60 n/mm tenders
f 270, 287, 305, 320
r 296, 312, 330, 350 opt1 235, 252, 269, 286 opt2 284, 298, 314, 333
Bill Verburg
Old 05-07-2009, 01:42 PM
