What's a Good Idle?
Ok, new month, new problem.
![]() My car normally idles around 800 rpms. Just took it to the shop to get new brakes, and came away with new chain tensioners...well, I knew it was going to happen sooner or later. Anyway, I noticed when I left the shop that it was idling around 550 rpms, which I thought was a bit odd. Drove it for a couple of days and it was back to it's normal 800 rpms. However, today I was at a stop light thinking someone's car sounds loud...alas, it was mine. Idling at a steady 1050 rpms. That seems a bit odd to me. Two questions: 1) Should my car be idling that high? Granted, first summer in a hot state, Nevada from Ohio. 2) What do I have to do to lower my idle? Last time I did it...someone said I did it wrong and was screwing with the cruise control. Oops.Note sure if this is of note, but after a good rev, it drops to 800 and then sticks right at 1k. If you do a search for my name, you'll notice that I had a hunting issue a while back due to a bad Autothority MAF unit. Have since swapped in the original OEM box and have not had hunting issues since. The car is 1987, so fuel injected and pretty much stock all around except for some cosmetic stuff. Brand new chain tensioners. Thanks!
-= Kaliv Farstryder =- '87 Porsche 911 |
Jupiter 911
Mine has always been between 800-850!
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
I think the manual says 880 for the 1987 model. I prefer 950 or so. 880 seems to be just a bit low for my taste.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Went looking through my old hunting idle threads and found an excerpt from Steve Wong, http://www.911chips.com/C1INSTR.pdf
