-   -   Is this normal? (http://forums.pelicanparts.com/porsche-911-technical-forum/4727-normal.html)
beepbeep 06-07-2001 01:42 PM
Is this normal?
Hi guys! I just bought 81' 930 and i'm trying to fix all small (hopefully) things. One of them is that oil-temp gauge never moves much than 4-5 mm's (barely over white cube). Gauge gets pegged if i ground the wire. I also changed temp-sensor to get rid of that possibility.
This is approx. what gauge reads when driving and engine is warm:
http://www.pelicanparts.com/ultimate...loads/temp.jpg
Thank you!
Automahn 06-07-2001 01:54 PM
Well I dont have a turbo but thats where my 81 911SC guage reads too, it gets a little higher when its 100+ degrees outside sounds pretty normal to me.
makaio 06-07-2001 02:15 PM
my 78 sc runs between 8 & 9 o'clock, with that same dial gauge.
Matt Chamblin
78 911 SC
Bob W. 06-07-2001 02:42 PM
My '81 930 ran at the same temp as your guage shows. My 78 911SC ran hotter so I thought the guage was not correct. I converted to the temp guage with numbers and it still ran at 180. I even replaced the thermostat (over $200 used) and it made no difference. My conclusion is that the turbo engine with its lower compression and conservative cam and ignition timing just runs cooler. On the street, I can not get it to run much hotter. On a very hot day with the air on and sitting in traffic it will heat up to 220 but as soon as I start moving the temp drops back down. I have a front dam mounted B$B oil cooler.
Bob W.
beepbeep 06-07-2001 02:52 PM
Thank you very much for your suggestions!
I'm living in sweden and it's still pretty chilly here despite summer coming. And gauge gets a little bit higher when i press it on the motorway so i believe it's not the termostat (>200$ new!!!). Also, when a drive for a few minutes pipes going to front oilcooler are still cold, which implies that termostat hasn't opened and is working properly. Probably just gauge being old & worn http://www.pelicanparts.com/ultimate/smile.gif
Now if i just could find out where the funny screeching sound from a back is comming from (it's following wheel rotation, but it's not rumbling)...hopefully not the wheel bearing http://www.pelicanparts.com/ultimate/frown.gif((
Doug Zielke 06-07-2001 04:26 PM
beepbeep,
Good shot of the gauge!
That is exactly where mine sits in Summer (West Coast of Canada).
If I get stuck in some real slow traffic, it might rise about 2 needle widths, cooling off after you start moving again.
Doug
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
members.home.net/zielke/911SC.htm
[This message has been edited by Doug Zielke (edited 06-07-2001).]
