915 - removing short shift kit
when i purchased my 74 Euro Carrera 2.7L, it came fitted with a short shift kit. the transmission was fully rebuilt by a reputable porsche independent shop.
however, i have not been 100% satisfied with the feel of shifting. for example, i must always slide it into 2nd before going into first in order to prevent crunching, shifting from 2nd to 3rd can be at times be difficult, 2 or 3 attempts may be required to get it into 3rd, and so forth. some people have suggested that i remove the short shift kit and this will improve it. if i wanted to go back to the original set up (ie long throw), what parts are needed and where can i purchase them? what about a 915 wevo classic shifter? will this improve the feel of my shifts? thoughts and comments welcome thanks |
At the track = great day
I'd realign the shift coupler before blaming it on the short shift kit and see if that fixes some of your issues with not being able to shift into the gears.
A Wevo classic shifter is a short shift kit.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
short shifts suck. just find a complete used shifter unit and bolt it on.
Adjust the clutch, too. Do what is called a basic adjustment, as opposed to just checking the clearance at the lever. You can search this forum for the details or look in the Pelican technical articles section. If you buy a complete shifter, get one out of a '77 to '84 model car.
JR |
I have the same deal. luckily I saved the old shifter though the knob is stuck on the factory short shifter so I have more of an issue then I like
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
the factory short shift is great. adjust clutch then readjust linkage. if you have weltmeister kit replace with factory kit
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
grateful user
shifting
i love my factory short shift kit, like a whole nother car.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
The parts can be ordered from Porsche. However, individual parts are more costly than a complete kit. Also available from our host; also available new and used here and on eBay.
Sherwood |
I have the WeVO classic in my '83 SC and am very happy.
Ruby911
I have some shifter parts from my 915 - I sent you a pm
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Some comments
See my comments in red below
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
