77 911 Exhaust Backdate
I want to backdate the exhaust on my 77. I purchased a nice set of 72-73 MFI heat exchangers a while back. Do I need to remove the shield on the one side and plug the hole/pipe above it if I use it? Would it work just fine if I leave it as is? I hate to change a good MFI unit if someone needs it and has one to swap for this one, but I don't know if anyone would be interested?!!?!?
'77 911S '72 BMW 3.0 CSL |
Anyone know?!!?!?!?!
RE #1, I don't know if you can swap MFI with CSI heat exchangers, will these even fit? Are they the so-called "thick flange" I understand the 1977 needs? RE #3, looks like part of the shield on the upper exchanger is missing or gone, is this correct? Were these ever symmetrical? Looks like some years don't have this shield at all. Engine Conversion 3.6L > Porsche 911 Chassis Package Parts And Accessories For Porsche Distributed By Patrick Motorsports RE #3, I don't know what that shield and hole are supposed to do, maybe somebody else will chime in. How does the original thermal reactor play into all of this, or is it long gone?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
It would be a good idea to plug the heat riser hole but probably not essential, it would tend to create an isolated hot spot above it. '77 will use the same thin flange as a '72/73
Porsche 911 & Carrera Exhaust Pipes - Page 2
Thanks.
No Longer MFI
I removed the heat stove and the heat riser tube and closed the hole. Thanks for your input on this. RB
