dvl dvl is offline
993 grinding noise while slowly accelerating
Hi,
my 993 (135k miles) emits grinding (metalic) noises when accelerating at low speeds (in the 1200 - 1800 rpm area).
If I accelerate carefully (very slow increase in rpm), the sound is not audible.
Everything beyond 2000 rpm is just fine.
Car shifts gears nicely, is fast (went for approx. 80 miles @ 150+ mph without any strange noise) and does the nordschleife just fine, sounds great doing it . 21 mpg fuel consumption and a 1/2l of oil (10W40 btw) on the last 3000 miles.
Just the grinding noise does not grow on me... Ignore it and hope for the best?
Thanx for your time,
Dirk
Old 05-04-2009, 11:14 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
Originally Posted by dvl View Post
Hi,
Dirk
I'd be careful going those speeds (150+ ) while your car is making grinding noises from the drive train! Just because you don't hear it at high speed doesn't mean the grinding/noise isn't there. There's a lot of noise at those speeds to cover it up.
It could be CV joint(s) ready to let go. I wouldn't want a CV joint to fail on me at 150! Have you tried jacking up the car and turning the wheels by hand to see if you can narrow down the location of the sound? That is where I would start. CV's tend to make noise under load when they're bad (in my experience).
1981 SC ROW Coupe
Old 05-04-2009, 12:25 PM
might also make sure IF you have a dual mass flywheel that its not failing.... they can get pretty noisy at low RPM. I saw a pictures of a failed dualmass flywheel and it damaged the bellhousing pretty bad.
I have a RS flywheel in mine and my gears rattle at low rpm, by 2k rpm everything is nice and quite.
Old 05-04-2009, 01:39 PM
dvl dvl is offline
The sound definitely disappears. If i leave the 1200-1800 rpm band there is no grinding at all.
No, i guess i have to check with a new mechanic. The last one said that this sounds normal for a car with this mileage. I drove a similar 993 with 100k miles and this lacked the noise though ...
Regards,
Dirk
Old 05-04-2009, 01:47 PM
1980 911 SC
Are you carrying a fire extinguisher?
A broken CV joint at speed could create some sparks!
Life's a Beach
Old 05-04-2009, 01:57 PM
Go Speedracer, go!
I'm not saying that's definitely what it is, but that would be my first guess. I don't think any car should make a noise like that, no matter what the mileage is. I'd say it's time for a second opinion, or a new mechanic. Either way let us know what it ends up being.
Check this thread for results of a broken CV joint at speed: CV Joint Failure Carnage And he was only doing 65mph.
I didn't think about the dual mass flywheel on the 993s. I know those can be noisy. My S4 has one too, and I dread the day I have to replace that thing.
1981 SC ROW Coupe
Old 05-04-2009, 03:01 PM
dvl dvl is offline
The broken CV joint looks scary. I'll try to record the sound, maybe this sheds some light on the issue. And i speed up the 2nd mechanic review.
Thanx,
Dirk
Old 05-04-2009, 03:35 PM
dvl dvl is offline
Hi,
the opinion from my 1st mechanic stays the same: this is normal for 993 with the longer gear transmission ratio, some cars got it more, some less.
Slow acceleration in 2nd and 3rd gear from 1000 rpms to ca. 16000 rpm:
http://2scale.net/~dvl/accelerate-2nd-3rd-low-rev.mp3
The recording is not very good, but its possible to hear the grindy noise in the background (i assume gearbox). Other than that the car drives great considering the mileage (130k), but especially stop and go annoys me.
I'll visit another garage next week, but im interested in your opinion.
Thanx,
Dirk
Old 05-07-2009, 12:32 PM
dshepp806's Avatar
can't get the link to work...
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-07-2009, 02:52 PM
dvl dvl is offline
Doyle
Hm?
dvl@weird:~$ curl -O http://2scale.net/~dvl/accelerate-2nd-3rd-low-rev.mp3
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 728k 100 728k 0 0 594k 0 0:00:01 0:00:01 --:--:-- 626k
Works for me. Maybe your browser doesn't know how to handle mp3 files? Right-click and download as .....
Cheers,
Dirk
Old 05-07-2009, 03:06 PM
