1981 SC Tachometer going wild ???
Started yesterday , Was running smoothly on the highway when
I saw the tach starting acting funny going to 7000 rpm`s and back down to 0,
It did this intermitently until I got home and shut the engine off. I also noticed
that when applying the trottle it would jump back & forth ???
I also could ear the gears in the tach spinning like crazy ?
Anyone knows what is going on .......... Is My tach going south ?
Francois
Old 05-05-2009, 09:12 AM
T77911S's Avatar
put a multimeter on the battery with the car running and check the volts. should be around 14v
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-05-2009, 09:22 AM
tach
Would that have something to do with the charging system ?
Francois
Old 05-05-2009, 09:26 AM
Francois
usually does. there are exceptions. when you're almost out of battery voltage to run the car (fuel pump), the radio quits and the tach floats, you better start looking for a place to land.
206 637 4071
Old 05-05-2009, 09:33 AM
Free minder
Aurel's Avatar
This happens when the voltage in the system becomes too low. I used to have this issue and solved it by cleaning my battery posts.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 05-05-2009, 09:41 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I had the exact same issue and I replaced the alternator and that solved it. If I remember right, if you have the alternator with teh separate voltage regulator you ban start there, otherwise try the alternator. In my case I ran it until the battery died, this gave me another sympton it was the alternator. Good luck!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-05-2009, 09:49 AM
Wildman Emeritus
Could be as simple as a loose battery cable clamp. Don't ask me how I know.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 05-05-2009, 09:56 AM
azporsche911.com
Hoffmanmotors's Avatar
My car did this same problem of the tack needle bouncing along with my head lights dimming intermittently at night. Turned out to be the voltage regulator had gone bad.
But find out if you have an internal or external regulator, my car at one point had been converted to an internal but the external reg was left in place. i bought the external reg and it didnt fix the problem, so i removed the alternator and discovered it was converted. after i took it to a place here in town to get rebuilt (paid about $40), all was good.
-Jeff
Jeff Hoffman (Son)
Tom Hoffman (Father)
79 911sc ROW guards red coupe
father son project.
Old 05-05-2009, 10:08 AM
Tach
2nd the bad voltage regulator
Old 05-05-2009, 10:36 AM
RETIRED
Joe Bob's Avatar
Mine was the precursor to the alternator goes tits up....
2012 ML350 3.0 Turbo Diesel
Old 05-05-2009, 01:41 PM
Just happened to me last week too. It then led to a dead battery. Turns out it was the alternator.
Old 05-05-2009, 01:59 PM
Happend to me too. Mine was an alarm wire (siren) that had slipped out of the harness, rubbed off the insulation, and was intermittely grounding out against the frame. A small bit of electrical tape and re-routing of the wire fixed the problem.
Check for loose connections or rubbed wires. Past that its either the alternator or the regulator.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 05-05-2009, 02:23 PM
Skitstoval's Avatar
Check the plug connection on the bottom of your CD (ignition) unit, sometimes get knocked a bit when changing your fuel filter
1981 SC Targa Euro - Minerva Blue
2003 Audi A4 1.4T
1999 Audi A4 1.4T - Hers
Old 05-05-2009, 05:01 PM
Head416's Avatar
Originally Posted by mikez View Post
mine was the precursor to the alternator goes tits up....
+1
Aaron
'81 911SC RoW Targa
Old 05-05-2009, 06:50 PM
wild tach
gees , thanks for all the inputs guys. I will have a look asap and try to
pin the problem.
Great forum
Will keep you posted
Francois
Old 05-06-2009, 09:11 AM
A whole collection of electrical gremlins were eliminated when my faulty alternator was relpaced..... including the bouncing tach.
Good luck.
1989 Carrera Coupe (Black / Linen)
1981 911SC Targa (Black / Chocolate)
Old 05-06-2009, 05:25 PM
SteveinTO's Avatar
Alternator/voltage regulator/battery/cables. One or all going Tango Uniform.
Old 05-07-2009, 10:04 PM
chocolatelab's Avatar
Hi
Ive got the same issue and ....
Would this wire have anything to do with it. It is hanging down from under the dash. It must be live because I tucked it under the dash and then the lights, wipers and other electrical stuff quit working. Any idea what it is. I
Old 05-08-2009, 10:20 PM
Cooper911SC's Avatar
BROWN is GROUND. General rule with Porsche. Check your voltage output from your alternator. check battery voltage with car off first...say 12.8 V. Then check it with car idling...should be 13.8-14.2 V. If it is higher your regulator may be bad.
The wire in your pic looks like it has a resistor in line. That may be the wire for the instrument with your alternator warning light in it. Some require the resistor to excite the alternator. Does your alternator light work when you turn your key to accesory position?
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 05-08-2009, 10:41 PM
Which light is the alternator light?
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 05-08-2009, 10:58 PM
