chocolatelab's Avatar
reverse light relay/switch?
Another question from the new guy trying to find the electrical gremlins
The reverse lights dont work. Doesnt appear to be a fuse issue and its not the bulbs.
Is there some sort of relay or switch at the transmision that activates the reverse lights?
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 05-08-2009, 10:34 PM
Cooper911SC's Avatar
Yep. Look under the car between the back of the transmission and the firewall. (Toward front of the car). The switch should have a rubberboot over it. It is kind of sandwiched up above the transmission mount bar. On my SC the plug had fallen apart and somone had "repaired" it by trying to zip-tie the bullet conectors into the switch. Another thing that can happen is that there is a pin inside the switch/trany that gets worn down or can shea off. Sometimes the reverse lights get stuck "on" if it shears.
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 05-08-2009, 10:48 PM
Hey thanks
Would it be called a " reverse light switch"?
Are you going to the pca deal at the queen mary in a couple weeks?
2016 BMW 328D wagon
Old 05-08-2009, 10:54 PM
Yes I will be at the GPX Concours. We will be in my wife's 993. Look us up!
We are just doing the display class...
Coop
PCA/OCR since 1997
Old 05-08-2009, 11:12 PM
PS you are right... reverse light swith. Kind of expensive!
PCA/OCR since 1997
Old 05-08-2009, 11:13 PM
That is awesome
see you there
I am going to do the wash and shine
I figure its a good way to see what going on
2016 BMW 328D wagon
Old 05-09-2009, 05:37 AM
Bill Verburg's Avatar
The reverse light switch on a 915 is next to the shift rod, there is a rubber boot that covers it
The white 2 pole thing to the left(from this perspective) of the shift rod
It could be the wire, the switch or the internal pin causing an issue, You can test by shorting the 2 wires to each other.
Bill Verburg
Old 05-09-2009, 06:07 AM
