-   -   reverse light relay/switch? (http://forums.pelicanparts.com/porsche-911-technical-forum/473516-reverse-light-relay-switch.html)
chocolatelab 05-08-2009 10:34 PM
Another question from the new guy trying to find the electrical gremlins
The reverse lights dont work. Doesnt appear to be a fuse issue and its not the bulbs.
Is there some sort of relay or switch at the transmision that activates the reverse lights?
Cooper911SC 05-08-2009 10:48 PM
Yep. Look under the car between the back of the transmission and the firewall. (Toward front of the car). The switch should have a rubberboot over it. It is kind of sandwiched up above the transmission mount bar. On my SC the plug had fallen apart and somone had "repaired" it by trying to zip-tie the bullet conectors into the switch. Another thing that can happen is that there is a pin inside the switch/trany that gets worn down or can shea off. Sometimes the reverse lights get stuck "on" if it shears.
Cooper
chocolatelab 05-08-2009 10:54 PM
Hey thanks
Would it be called a " reverse light switch"?
Are you going to the pca deal at the queen mary in a couple weeks?
Cooper911SC 05-08-2009 11:12 PM
Yes I will be at the GPX Concours. We will be in my wife's 993. Look us up!http://forums.pelicanparts.com/uploa...1241849499.jpg
We are just doing the display class...
Coop
Cooper911SC 05-08-2009 11:13 PM
PS you are right... reverse light swith. Kind of expensive!
chocolatelab 05-09-2009 05:37 AM
That is awesome
see you there
I am going to do the wash and shine
I figure its a good way to see what going on
Bill Verburg 05-09-2009 06:07 AM
The reverse light switch on a 915 is next to the shift rod, there is a rubber boot that covers it
The white 2 pole thing to the left(from this perspective) of the shift rod
http://forums.pelicanparts.com/uploa...1241874340.jpg
It could be the wire, the switch or the internal pin causing an issue, You can test by shorting the 2 wires to each other.
