Porsche Crest 1980 911SC idle problem
1980 911SC idles fine when cold. wants to idle between 2k and 2.5k when hot any suggestions
Old 05-09-2009, 10:06 AM
FinallyGotOne's Avatar
warm up regulator not working properly?
Old 05-09-2009, 10:09 AM
It could be several things, AAR, vacuum leaks, incorrect tuning to compensate, etc. , more likely an air problem than a fuel problem. Is this a new problem and did it happen without changing anything? The first thing I would look at is the vacuum hoses at the distributor and the ignition timing. The idle speed is set with the vacuum retard connected and if the diaphragm or hose leak, the hot idle will climb.
Paul
Old 05-09-2009, 10:54 AM
Designer King
Paulporsche's Avatar
Check your decel valve too.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-11-2009, 11:45 AM
