caribdis7
911SC. Which is the correct location of the aerial?
Hello,
I have a doubt about which of the to aerials I have in my 911SC is the original. This is a German car LHD and when I bought it, came with 2 antenas, one at the left and one at the right. My idea is to cancel the non original one but when I check photos of other 911s I am not sure which is the right wing where the aerial came originally. Could you help me to tell which is the correct one? At the side of the fuel cap or at the other side? regards
passenger side
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
I am my 911's PO
There was a discussion about this once (try a search), but IIRC, the consensus was power antenna on the passenger side, manual on the driver side. I ordered my '78 with radio delete and it arrived with a manual antenna (on the driver side).
Are both fenders original?
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive Last edited by '78 SC; 10-03-2011 at 07:00 PM.. Reason: typo |
manual-DS
power-PS
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Insert Tag Line HERE.....
if thats an SC, someone has changed out a fender, as well as the front lower valance and headlights... what year is it????
caribdis7
You are right. It is an SC with "Carrera" front fender. I bought the correct SC fender to replace it.
Both aerials are manual. I was told that the previous owner added one of it for getting more frecuencies, (something I really dont understand) I am thinking to install an electrical one, so as per the comments all of you give, I should keep the passenger one. Just that position of the passenger existing one looks a little bit on a side. Dont you think so? Any preferences about manual or power one? Which one do you recommend? |
If you want to, measure from the closest part of the gap between the fender and trunk lid, to the center of your antenna hole. Mine measures 3 7/8" to the rear center of the hole, and 4" to the front center of the hole (with a measuring tape placing the right angle end into the gap and pressing it against the fender).
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 10-04-2011 at 02:04 PM.. |
Here's the position of my power antenna on my 1983SC (RHD).
My first love - 1993 964 C2 Manual Coupe My second love - 2021 Macan GTS |
1978 sc
1978 sc euro................left side manual
1978 911sc cpe 1986 944 N/A sold to pelican 1965 series 2a 88 landrover sold 1964 series 2a 88 landrover sold 1988 944 white. sold |
My U.S. 1979 911SC w/ factory power antenna.
Ray H. 1979 911SC Coupe 2000 986 |
My choice would be a power Hirschman unit, and a body plug for the hole in the driver's side fender.
Keep the Shiny Side UP! Pete Z. |
caribdis7
Thanks evrybody.
I think I will keep the drivers aerial (it looks to me the original one) and install a power antena. I hope the motor will fit inside. Regards |
GOM (Grumpy Old Man)
Double check if there is room for the motor. I recall there was a reason the power antennas were on the PS. I don't believe there is room for the motor on the DS.
Instagram: @3pedalposse |
Fb = M/S
There is no room for a power antenna on the drivers side. The fuel filler gets in the way. Prior to 1982, the SCs had an option for the power antenna on the PS. I think after 1982 all SCs came with a power antenna on the PS. My 81 SC has a manual antenna on the drivers side and it is VERY difficult to get to.
My advice is to put a power antenna on the PS and don't look back. |
I just threw away a power antenna from a Carerra a few days ago.. hate them. In the past I have used the small 6-7" black whip which looks good and works great.
My SC has the power antenna on the passenger's side...
Arnie Diaz Braselton, GA ------------- 1982 911 SC (3.2), Fabspeed Bypass and Muffler 2003 E39 BMW 530i (Daily Driver) |
