Radical - oil leak finding approach
I thought I'd share my own, radical, approach to finding oil leaks, their travel patterns, and destinations.
- Cover all suspect areas of the motor underside with standard, white, (baking) flower. - Start motor until warm. - The oil flow mixing with the flower will show you clearly where the leaks generate, travel, and stop. - Wash off motor after identifying. Clearly not a modern factory approach but then neither was the work done at Gmund. Jacob |
do you use white carnations? Just kidding , that is a clever idea.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I had a similar idea using talcum powder but haven't tried. So it worked? Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Autodidactic user
This is similar to using a fluorescent oil additive. You add this stuff to the oil, drive around for a while, then shine a black light wherever you suspect a leak. The dye glows yellow when you shine a black light at it. Instead of following the oil path through the flower, you just follow the glowing oil path! It's a lot less messy! Here is an example of the type of product I am talking about.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
muck-raker
and flowers will make your oil smell pretty. If all else fails, I guess you could use flour?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
They won't get it.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
muck-raker
Autodidactic user
"There are anywhere between 1,500 and 2,000 languages in Africa, most of which are still poorly documented."
English may be Jacob's primary language but since he lives in Africa I say we give him the benefit of the doubt and ask the heterograph police to back off a bit.
Band.
I've used the "flour" method in other (non-automotive) aspects of my life, with fantastic results.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
muck-raker
dude, your killing me!! ![]() Mr. Clark---no harm, no foul. Just having a little fun, no disrepect intended. FWIW, it sounds like a decent idea.
Autodidactic user
muck-raker
wow...fowl indeed!!!
I smell an opportunity for all the Boxster Bashers. Aaannd.....GO.
abit off center
This is also a poor mans way to check for cracks in alum, soak the part in ATF, wipe it dry and dust it with flower and the crack will show up.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
We used to use Right Guard or Brute antiperspirant with powder. Same principle. Worked very well, and smelled good too.
Jon |
