jmiemiec's Avatar
Radical - oil leak finding approach
I thought I'd share my own, radical, approach to finding oil leaks, their travel patterns, and destinations.
- Cover all suspect areas of the motor underside with standard, white, (baking) flower.
- Start motor until warm.
- The oil flow mixing with the flower will show you clearly where the leaks generate, travel, and stop.
- Wash off motor after identifying.
Clearly not a modern factory approach but then neither was the work done at Gmund.
Jacob
Old 05-16-2009, 09:06 AM
do you use white carnations? Just kidding , that is a clever idea.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-16-2009, 10:30 AM
I had a similar idea using talcum powder but haven't tried. So it worked? Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 05-16-2009, 10:54 AM
Autodidactic user
David E. Clark's Avatar
This is similar to using a fluorescent oil additive. You add this stuff to the oil, drive around for a while, then shine a black light wherever you suspect a leak. The dye glows yellow when you shine a black light at it. Instead of following the oil path through the flower, you just follow the glowing oil path! It's a lot less messy! Here is an example of the type of product I am talking about.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 05-16-2009, 10:58 AM
muck-raker
kidrock's Avatar
and flowers will make your oil smell pretty. If all else fails, I guess you could use flour?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-16-2009, 12:28 PM
They won't get it.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-16-2009, 12:43 PM
muck-raker
kidrock's Avatar
Originally Posted by formerly steve wilkinson View Post
they won't get it.
lol
STONE
Old 05-16-2009, 01:06 PM
Zeke's Avatar
Originally Posted by Formerly Steve Wilkinson View Post
They won't get it.
Well, thiers an example of how there finding ways to locate oil in they're.
You're approach might be different that what your thinking.
Old 05-16-2009, 01:11 PM
Autodidactic user
"There are anywhere between 1,500 and 2,000 languages in Africa, most of which are still poorly documented."
English may be Jacob's primary language but since he lives in Africa I say we give him the benefit of the doubt and ask the heterograph police to back off a bit.
Old 05-16-2009, 02:27 PM
haycait911's Avatar
neat idea. dye approach here.
engine oil dye to find leaks
Old 05-16-2009, 03:31 PM
Band.
I've used the "flour" method in other (non-automotive) aspects of my life, with fantastic results.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 05-16-2009, 03:38 PM
muck-raker
kidrock's Avatar
dude, your killing me!!
Mr. Clark---no harm, no foul. Just having a little fun, no disrepect intended. FWIW, it sounds like a decent idea.
STONE
Old 05-16-2009, 05:18 PM
Autodidactic user
None taken but I have to disagree with you. Fowl can do some real harm!
Old 05-16-2009, 06:51 PM
muck-raker
kidrock's Avatar
wow...fowl indeed!!!
I smell an opportunity for all the Boxster Bashers. Aaannd.....GO.
STONE
Old 05-16-2009, 07:20 PM
abit off center
cgarr's Avatar
This is also a poor mans way to check for cracks in alum, soak the part in ATF, wipe it dry and dust it with flower and the crack will show up.
______________________
Craig
G2Performance
Old 05-16-2009, 07:22 PM
shbop's Avatar
We used to use Right Guard or Brute antiperspirant with powder. Same principle. Worked very well, and smelled good too.
Jon
Old 05-16-2009, 07:30 PM
