-   -   Help with part # please (http://forums.pelicanparts.com/porsche-911-technical-forum/475056-help-part-please.html)
mthomas58 05-18-2009 05:22 AM
This rubber reducer fitting to the right of the oil filler cap is cracked. I'm hoping to be able to repair it using self fusing silicon tape. If this does not work, I'll have to replace. I have not been able to find the part number. This is on an 87 Carrera.
http://forums.pelicanparts.com/uploa...1242649242.jpg
Fast Corners 05-18-2009 08:24 AM
Rubber Sleeve is 930.207.243.01
Small Clamp is N023.526.3
Large Clamp is 999.512.060.02
The metal Valve is 930.207.229.00
And the clamp that you are missing (on the hose the valve is attached to away from the reducer a.k.a. rubber sleeve) is N023.569.2
kidrock 05-18-2009 08:49 AM
I have the same problem. I sprayed it with the motor running, but the idle stayed the same...the cracking may not be severe enough yet. If cracked badly enough, can I assume this may create vacuum leak?
Four Corners, thanx for the diligence...in case I haven't mentioned it before, I'm notoriously lazy.
mthomas58 05-18-2009 04:17 PM
Originally Posted by fast corners (Post 4669973)
rubber sleeve is 930.207.243.01
small clamp is n023.526.3
large clamp is 999.512.060.02
the metal valve is 930.207.229.00
and the clamp that you are missing (on the hose the valve is attached to away from the reducer a.k.a. Rubber sleeve) is n023.569.2
thanks!!!!!
......oops part shows NLA on Pelican.
