Throw it on the ground!
Help with part # please
This rubber reducer fitting to the right of the oil filler cap is cracked. I'm hoping to be able to repair it using self fusing silicon tape. If this does not work, I'll have to replace. I have not been able to find the part number. This is on an 87 Carrera.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 05-18-2009, 05:22 AM
Fast Corners's Avatar
Rubber Sleeve is 930.207.243.01
Small Clamp is N023.526.3
Large Clamp is 999.512.060.02
The metal Valve is 930.207.229.00
And the clamp that you are missing (on the hose the valve is attached to away from the reducer a.k.a. rubber sleeve) is N023.569.2
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 05-18-2009, 08:24 AM
muck-raker
kidrock's Avatar
I have the same problem. I sprayed it with the motor running, but the idle stayed the same...the cracking may not be severe enough yet. If cracked badly enough, can I assume this may create vacuum leak?
Four Corners, thanx for the diligence...in case I haven't mentioned it before, I'm notoriously lazy.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-18-2009, 08:49 AM
Originally Posted by fast corners View Post
rubber sleeve is 930.207.243.01
small clamp is n023.526.3
large clamp is 999.512.060.02
the metal valve is 930.207.229.00
and the clamp that you are missing (on the hose the valve is attached to away from the reducer a.k.a. Rubber sleeve) is n023.569.2
thanks!!!!!
......oops part shows NLA on Pelican.
Mark
1987 911 Coupe
Old 05-18-2009, 04:17 PM
