tquaglino's Avatar
85 Carrera, Is this normal?
With the car off. The electric windows still operate.
Also when I stop the car with the turn signal flashing I am left with the yellow indicator still lit? This turns off when I straighten out the stalk.
I've had this car for 10 years and never noticed these items until recently.
Is it normal and if not what could it be?
Thanks, Tom
Old 05-21-2009, 09:24 AM
Friend of Warren
The electric windows should still work after turning the car off until you open one of the doors. As to the turn signal, yes the left one will stay lit with the car off. A European safety feature when parking on a dark, narrow street.
Kurt V
Old 05-21-2009, 09:27 AM
tquaglino's Avatar
Thanks, I thought I was looking at spending more money. phew.
Old 05-21-2009, 09:44 AM
Ain't it great to be normal
Old 05-21-2009, 10:16 AM
do your windows stop working when you open a door? If not, one of your door switches is likely broken (not allowing the interior light to come on). This is an easy fix, you simply remove the offending switch and clean off the corrosion.
Old 05-21-2009, 10:47 AM
Goldfinger
Mattcamp's Avatar
The right one will stay on too if you select the right signal. Never know what side of the road you might park on.
1984-Carrera (pewter metallic)
Old 05-21-2009, 10:55 AM
muck-raker
kidrock's Avatar
those Germans have thought of everything.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-21-2009, 06:08 PM
