cds problem
does anyone know how to check a cds unit while out of the car,there are three tabs,can i do a normal ohms check,or will it kill the ohmeter because of the stored voltage,all and any help will be greatly appreciated thanks,frank
Old 05-31-2009, 05:11 PM
T77911S's Avatar
take the cover off the back. jumper point 4 (labled Cs) to pin A. remove jumper. then connect your MM ( ohms) to the same 2 points. the metter should start "counting". the resistance will get higher and higher until it reaches an open or close to it, been a while since i checked one. if your MM does nothing, the capacitor is bad. if it shows a dead short, it is bad. thats really about all i can go thru with you with out getting into it deep. try the test a few times just to make sure.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-01-2009, 04:56 AM
