GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Water through Ventillation ?
On my 71 I am getting water coming through my lower dash vents ( floor vents) after I wash it or in a big rain. Any ideas as to why and how to fix this?
I guess its coming from the vent near the hood and then travelling down to my feet.... ??
Old 05-25-2009, 11:07 AM
Air Medal or two
afterburn 549's Avatar
Windshild gasket if you cant find anything else
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-25-2009, 11:44 AM
PRO Motorsports
Tyson Schmidt's Avatar
Make sure the drain hose isn't clogged. It's the one that runs down into the smuggler's box and out the bottom of the car.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-25-2009, 12:15 PM
GotaT's Avatar
The Winshield gasket appears pretty new and I dont see any visible water coming through it on the inside of the car.
Ill check the drain.. Thanks!
Old 05-25-2009, 06:19 PM
moneymanager's Avatar
Check the corner edges of the windshield gasket. A one year old gasket can leak, if car is left out in weather. Any gap at the corners is suspicious. There are lots of threads on water leaks here, do a search. About every possible offending component has been identified by someone else.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 05-25-2009, 08:53 PM
Also, check the trunk seal along the cowel. Water can flow over a worn seal and drip onto the connectors for the floor vents and leak into the passenger compartment. Test all suggested areas with a hose, starting at the lowest point first (cowel, air vent, windshield at lower corners, windshield at upper corners.) BTW, check to see if the drain hose from the airbox is cracked or disconnected, as well as being clogged.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-26-2009, 07:56 AM
