Eck Eck is offline
78 SC, what is missing?
What is missing here, should there be a cover, there are two threaded holes that I've circled.
Kirk
78 911SC
Old 05-22-2009, 03:32 PM
scarceller's Avatar
The plastic cover
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 05-22-2009, 03:42 PM
pozee's Avatar
Plastic cover.
pozee
Old 05-22-2009, 03:43 PM
Almost Banned Once
sc_rufctr's Avatar
A Black Plastic cover... Triangular in shape with rounded corners.
A wing nut screws into the tag you have circled at the top of the picture.
This wing nut secure the cover. ($15.00 est for both at you local wreckers)
The bottom captive thread on the alloy bracket is not used for anything on my car. (nothing was ever there)
- Peter
Old 05-22-2009, 03:44 PM
It doesn't have to be plastic (or, as is more likely the case, pressed cardboard). Mine is carbon fiber. Saves me the weight of a sparrow's feather back where it's meaningful...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-22-2009, 04:45 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
got one if you dont find one locally.
FS: Parts from 1980 SC Track Strip
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 05-23-2009, 01:11 PM
"The bottom captive thread on the alloy bracket is not used for anything on my car. (nothing was ever there)"
In OEM configuration there is a second wing screw (with bearing washer) that engages that captive nut (there's a hole in the OEM plastic cover that aligns with this lower captive nut). This lower, second wing screw is often lost.
Old 05-23-2009, 05:09 PM
